What is your pinion on cyanogenmod? and some questions.
Solved by TheDigitalRealm,
OK so i am gettign the lg g2 and i just wanted to know what it means on the DL page whe it says its nightly but like the s3 has a stable version?
I would use the CM installer, as it will download the Stable version of Cyanogenmod for your device. Well, it did for my N5 anyway. I would definitely recommend CyanogenMod for the LG G2. It's an awesome piece of hardware, but LG's android skin is bloated and unnecessary.
