3 minutes ago, zealms said:
Which plug do I need to connect to my mb for my power button to function-ik it’s a huge mess rn it’s my first pc.
There should be a bunch of cables in there labeled Power SW (or button, really depends on the manufacturer but you should be able to recognize it), Reset switch, etc. Plug those into the corresponding headers as directed in your motherboard manual.
Where can I buy front panel connectors? | Tom's Hardware Forum
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1238409-help/#findComment-13955658
36 minutes ago, zealms said:
Yes I have those right here but where does this plug into?
What is the motherboard you have?
Main Rig:-
Server:-
https://linustechtips.com/topic/1238409-help/#findComment-13955720
15 minutes ago, zealms said:
X570-plus tug gaming
Main Rig:-
Server:-
https://linustechtips.com/topic/1238409-help/#findComment-13955751
