8 minutes ago, Mlek00 said:
I bought myself a gtx 1050ti. It have some scratches on it.
Should I send it back and get a new one or is it's nonsense ?
Are you sure these are scratches? To me, they look like leftover adhesive from stickers.
A bit of alcohol and a cloth/toothbrush (<- not one you intend to use in your mouth anymore) would probably help get rid of it.
https://linustechtips.com/topic/1238297-help/#findComment-13954867
Yes those are  a scratches I even can feel it
https://linustechtips.com/topic/1238297-help/#findComment-13954995
Does it work when plugged into your system? If it does, don't worry about it. If it doesn't, then RMA it, and tell them it doesn't work, and that there are visible scratches on the back.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1238297-help/#findComment-13955724
