Speedometer ish for viewing temp / cpu usage
So I wonder if there is any way to do this since I know an old case which had 3 of these and I would like to add to my case
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1237833-speedometer-ish-for-viewing-temp-cpu-usage/
i no the aqua computer 5.25 can display anything. or if you want just the software get the lt version of it
i no there are stand alone temp for water cooling .
So there is nothing?
Reminder⚠️
i think a Speedometer is for getting water speed.
i think what your looking for is an oled? or are you talking about software?
Trying to replicate something like this
images?q=tbn:ANd9GcQ4rzQw_Kgn3SDtvLup_a8
Reminder⚠️
i mean we need more info. how do you want to mount it? what dose each of them do. im guessing one is fan speed, one case temp, ad the other i don't no.
you might be sable to fine some old stuff in 5.25 bay that can do it.
the aqua computer can do it all.
Well I want to mount it inside the case and yes fan speed case temp the other one is usage or something (maybe unused)
Reminder⚠️
1 minute ago, thrasher_565 said:
something like this?
Yes something like that
Reminder⚠️
analog metros to pc i don't no how to do sorry.
Edited by thrasher_565
so back in the day 5.25 bay devices were common and there were all kinds of stuff you could buy but i don't no there names. best would to keep search ebay or something unless you no how to program and do electronics. there a few retro guys on you tube that unbox and build old pcs and they put these old 5.25 bays in there good place to get info i guess. like LGR for example. (keep in mind that these old 5.25 are no collectors and will cost a bit)
5.25 bay is dead. you can find say digital pc temp  and a 5.25 bay fan controller easy its the other stuff that's going to be harder.
If you feel like digging, there was an old episode on techtv, I think with Leo Laporte, where they did a custom case with a tachometer that moved with CPU utilization. They even programmed an idle mode that would bounce a little like a car will.
I don't remember how they did it, but it's possible!
