Weird pump noise?
Go to solution Solved by H6NS,
The thing is that during the shipping the AiOs create a lot of air bubbles inside of the cooling system. I'm pretty sure that you have nothing to worry about. Even Gamers Nexus quotes some cooling manufacturer in his video that you should leave it "doing its thing" for a day or so and it should calm down eventually.
Hi guys
I installed my new Kraken x63 today to replace one I have with a broken mounting bracket, however, the pump noise seems to be weird. Compared to my previous one, the noise of the water in the loop seems a LOT louder as shown in the video. Should I be concerned/should I return it and get a new one? Temps seem unaffected - getting 30 at the desktop and around 50 to 60 in games (~18 degree idle).
https://linustechtips.com/topic/1237768-weird-pump-noise/
3 minutes ago, TomH said:
Hi guys
Can you get us a picture of the entire PC? Depending how the pump and radiator are mounted, it may be more or less susceptible to getting air in the pump which can make that noise.
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950742
Hello, I heard that before when the pump was higher than the radiator. It was caused by air bubbles. I don't know which way you installed it, but it is generally recommended to have the pump lower than radiator (Gamers Nexus did a nice video about it).
CPU: Intel Core i7 8086K, Delidded with Der8auer Custom Nickel-Copper IHS and Coollaboratory Liquid Ultra CPU Cooling: Scythe Ninja 5 with Thermal Grizzly Kryonaut Thermal Paste Motherboard: ASRock Z370 Taichi RAM: 2x16GB Kingston Predator DDR4 3200 MHz 15-17-17-36 GPU: Gainward RTX 2080 Phoenix GS with Raijintek Morpheus II Core Black Heatpipe VGA Cooler, Thermal Grizzly Kryonaut Thermal Paste and 2x Scythe Kaze Flex PWM 120mm fans Case: SilentiumPC Regnum RG4T Pure Black TG Storage: Samsung 960 EVO 250GB, Samsung 970 EVO 500GB, Seagate ST4000DM 4TB HDD, Toshiba HDWD240 4TB HDD PSU: SilentiumPC Supremo FM2 Gold 750W Case Cooling: 6x Scythe Kaze Flex PWM 120mm fans Keyboard: Corsair Strafe Mechanical Keyboard Mouse: Trust GXT845 Tural Display: Sharp LC-50LD265E Operating System: Windows 10
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950746
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950762
Try mounting the radiator on the top of the case, it should solve the problem. Well, if the case is compatible with the top mount of your AiO...
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950774
Unfortunately it isn't compatible 😕 now that its been running for a little, it seems to have quietened down actually. So long as its not leaking or overheating, I should be fine right? I'm hoping to migrate to a new case soon so hopefully this will help.
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950794
So I guess this is the only way you can install it then. Try unplugging ang plugging the pump, sometimes it helps.
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950807
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950826
How the tube long enough for you to flip the radiator and have the tube at the bottom ?
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13950956
You could always relocate your top fan and flip the case on its head, that way the cooler can function properly
desktop
HTPC
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13951123
I have recently had an issue installing a NZXT Kraken Z73 AiO Liquid Cooler into my build which turned out to be a faulty product.... Can be found here (https://forums.tomshardware.com/threads/nzxt-kraken-z73-pump-not-working.3638406/) but as I mention in my post on Tom's Hardware, why does everyone talk about air bubbles in a closed line AiO Liquid Cooler?
"We also found online that some people are claiming that "Air Bubbles" get stuck in this pump and they shake the radiator to allow gravity to push the bubble out of the line..... but I am not sure how that makes sense as its a closed line so where would the air go? - lol" (View: https://www.youtube.com/watch?v=KNNLWPLqAYM
All this talk about "Air bubbles" in a closed line AiO Liquid Cooler cannot be true as the air has nowhere to escape... Just Saying
Subaru WRX 2011 Build: Click Here
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13951867
The AIOs come with air already in them. They don't fill them 100% so when someone says they get stuck in the pump, that's air moving into the pump from elsewhere and if the pump is put in a configuration in which the air can't leave back to the radiator, then it gets stuck.
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13951922
Ahh that makes sense. Must be the verbiage that throws me off.
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13951938
check out the gamersnexus video above. He demonstrates and explains
desktop
HTPC
https://linustechtips.com/topic/1237768-weird-pump-noise/#findComment-13952091
