WiFi card disabled when M.2 is plugged in
Solved by minibois,
3 minutes ago, QuantumBit said:I recently installed a M.2 (XPG SX8200) into my system, but as a result my PCIe wifi card doesn't work anymore. I have two PCIe slots, one for the GPU and one for the wifi card (I'm using an MSI b150 Mortar Arctic), so I can't really move it around. Is there any possible solution? I haven't had a good experience with powerline (quite expensive too) or USB wifi adapters. Running an ethernet is not a viable option either.
There are three PCIE slots, right?
The bottom slot is turned off, so you need to use PCI_E1 for the GPU, PCI_E2 for the wifi card
