6 + 2 pin wall power plug
Go to solution Solved by Kanna,
4 hours ago, Spudwell06 said:
Do you mean plug in by pcie to the mobo, and 6 + 2 pin on the extra psu?
Yeah
Just now, Spudwell06 said:
So a PSU just for a GPU?
Why do you only need to start the GPU?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
22 minutes ago, Spudwell06 said:
Cause I have a PSU for a prebuilt (I know that's blasphemy) it is soldered to parts, and a GPU needs additional power (r9 390)
Well another psu is the only option here
Reminder⚠️
Nearly everything that you plug into the wall has a PSU, either internally (like a desktop computer) or externally in the form of a power brick/adapter. No one makes a standalone 230V AC to 12V DC converter with a PCI-E output. Therefore, you need an entire ATX or SFF PSU.
However, in your situation, you should just accept that it is not feasible to upgrade to a graphics card that requires more than 75W if the proprietary PSU doesn't already have a PCI-E 8-pin. (If it has Molex, you can try adapters, providing that the PSU has enough wattage to support the GPU). Even if you hooked up a second PSU, the graphics card would be powered by two sources (75W from the motherboard and the rest from the second PSU), which have no way to communicate between themselves.
7 hours ago, Spudwell06 said:
So even if I did get another psu, it would not work
Oof
It would work as long as it is plugged in in the PC and the other psu
Reminder⚠️
Yeah
Reminder⚠️
