17 minutes ago, MikOL said:
<snip>
That's definitely too hot. Look at upgrading the thermal solution.
FYI for those who comment later, Tctl is a control temp, while TSI is the actual package temp.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946876
Yep TSI is remote probe. However its software driven, so would question the accuracy.
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946892
34 minutes ago, Moonzy said:
cpu temp seems high
make sure the fans are spinning, and might wanna re-apply thermal paste if you have some on hand
as well as blow on the dusts if any
I tried to re-apply thermal paste, btw im using mx-4
Thanks for the info man..
So does the TSI is not accurate enough?
this is the idle temp for now
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946924
50+ celcius difference between core temp and package temp would have me thinking it's not accurate. The core generates heat. However it can accumulate at the motherboard socket (package) and there is placed a sensor.
However this temp like most all amd chips works on an algorithm.  For example FX processor core and package temps where not accurate until some 40 to 45c and up.
Generally your core and package temps should be around 10c difference at most if the cooler is doing its job properly.
Somewhere between 100 and 110c that board would shut right off.
Feel the heat sink. If its 100c, itll be really hot. So mind the burns. Be careful. If it feels just warm to the touch, the cooler is fine, rely on the core temps instead.
All the other temps look great other wise.
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946954
I tried the amd overdrive and i just checked the temps, so i am really confused about the temps really, so this is the temps in amd overdrive
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946992
Yeah, I know.
Software pulling from sensors that dont exist may sometimes give a whact number.
Your pc is fine. Hwmonitor is fine on your system.
You can always try HWInfo64 and we can see if there a bunch more strange readings.
What's Coretemp say? Have you tried that one?
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946996
31 minutes ago, MikOL said:
This is the stress test for 15 minutes, do u think guys is this good temps? Or should i change my cpu cooler?
BTW, is this overclocked, or a 6700K? The 6700 is supposed to be a 65 W TDP.
Check the comments in this.
Interestingly, AMD lists Tctl as a measure of thermal margin, not absolute temperature. This is proven by the apparently sub-ambient minimums. I agree the temps are both a bit weird, but that's not uncommon for K15h.
Quote
This is a bit of a misnomer, sometimes the CPU will be hot and the heatsink cool, due to a bad TIM application.
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946997
bug in softwares.
broken sensors
all what  @ShrimpBrime said.
you are fine
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13946998
  Reveal hidden contents
Agreed.
However if the socket was that hot, the cores would be smoking too.
Not a big deal. Hes past 103c. Not quite shut down temp. I'd suspect he'd experienced that already by now based on the quick screen shot.
In addition yes, temps based off margin via algorithm.  Something about time and therms.
Knowingly the last temp you looked at was pulled just over a second ago. And that next one you just saw was 1second ago too lol.
Edited by ShrimpBrime
Additional comment.
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13947002
Okay first of all thank you for your concerns, so far my pc haven’t shut down yet, so thank GOD, so i tried the coretemps and it seems like this is the correct temps for my cpu, i tried to stress test it for 20 mins and my temps are 47-50c, and then i tried to use the thermal gun and the temps are 40-45c so i think the HWMonitor and HWInfo64 called “Whact Numbers” so i don’t know if could trust those numbers from them or does the coretemps are accurate enough? Btw i tried to touch the heatsink as well, ofc its hot but not that kind of hot, feels like 40c, this really interesting thread, and im learning from it, thank you..
this is the coretemps readings..
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13947029
No its not overclocked, so im just guessing that the sensors are off, i really need a correct reading of temps to my cpu, though im not bothered because its not even shuttiing down or any what, so i guess im good? lol
https://linustechtips.com/topic/1237257-cpu-temps/#findComment-13947036
