Okay, will this old tv work with my retro consoles
Lilninjsways
So I have been looking for a small tv for my retro games to put on my bookshelf
http://imgur.com/a/SMIgs2j
The person who is basically giving this and another away is saying that there is no way to hook up any retro console to the tv is this true?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
Yes but technically no. You could convert signals to coaxial cable but that is not gonna be cheap. I'd just look for a different random crt tv.
Damn, it was gonna be free and he was gonna drop it off at my door step. How "not cheap" is it? He said he can give me a " coax transformer"
RAM: 32gb ddr3
Around 50$ for one convertor box. Not guaranteed to work of course.
uuuh no it's not expensive? you can just use a VCR for that. at least where i live you can since all our VCR's have a SCART input that you can plug consoles into and it will output on RF.
he probably meant the thing in the pictures that converts the Coax RF to the terminals you connect to the tv where the antenna would normally go. it's not sueful for connecting consles unless the consoles you are using can output on RF. if they can't you'll need to use something like a VCR to convert the signal first.
She/Her
or just use a VCR if it has a composite input, basically all of them will take that input and output it over RF, at least the one's that i've used do.
She/Her
I've only come across that on the more expensive models I've seen around and used which were barely any. But good idea.
i have 2, a panasonic VCR that's nothing special, it doesn't even have hifi audio, and i have a JVC VCR that's super high end, S-VHS and all that, both take SCART and output it onver RF. i assume that regions that don't have SCART take composite and output it over RF.
She/Her
I'm guessing this wouldn't work?
RAM: 32gb ddr3
i can't tell if it has an RF output on it. if it does it theoretically should work just fine if it outputs whatever you plug into it over RF.
She/Her
No it doesn't seem to have RF it only has 4 different types of component
RAM: 32gb ddr3
then it's too new. try to find a VCR that's really cheap or even broken (remember we don't need to play tapes we only need the signal processing to work here, as long as that works we're good) that has both composite in and RF out on it.
She/Her
https://www.amazon.com/dp/B00J41Y4YY/ref=cm_sw_r_cp_apa_i_G6gqFbKGAZ2R8
Would this work?
RAM: 32gb ddr3
5 minutes ago, Ashley xD said:
from the description yes, but i don't know. i'm not super familiar with this stuff, i've always used old VCR's if i needed RF.
Should I just wing it?
RAM: 32gb ddr3
idk?
She/Her
