Do my AIO fans need to match the case fans?
Danny Peak
Should I get fans that match my case (pure Base 500) to replace the fans on my AIO (Cooler Master Seidon 240v)
I don’t know much about air flow but I’ve heard maintaining a neutral air pressure is important and different fans push different amounts of air
no. they dont need to be the same.
PS: positive pressure is usually better because it keeps dust out of your system.
How do I get positive pressure?
nevermind that was a dumb question
Edited by Danny Peak
Dumb question
What would be the best way to setup the fans
i.e where should the 240mm radiator and the 2 120mm case fans go
is this the pure base 500 or the pure bas 500dx?
What cpu/gpu?
What cpu/gpu?
Normal pb 500 and it’s just an ASUS 1050Ti
As there is no transparent side panel, I would go for more performance arranged fans rather than better looking configuration. set up the AIO at the top of the case as exhaust, a fan at the back as intake and then a fan at the lower front area as intake for the GPU. So you have 2 fans as intake and 2 as exhaust. if the intake is slightly fast RPM than the exhaust, then you get positive pressure.
