I have recently bought a tp-link 8 port switch and it doesn't work.I have a cat 6 wire running from my router and then splitting into 4 computers.Most of the times the computer doesn't even recongize the connection and if it does it flickers on and off.I have Huawei router
https://linustechtips.com/topic/1237034-ethernet-switch-issues/
7 hours ago, Haitham111 said:
I tried troubleshooting it said something about an ip configuration.
What gave you this report? Windows?
Is the Hauwei device an internet gateway? Can you state the make and model? I've seen where fiber ONTs from Hauwei have ports for specific purposes, e.g one for LAN, one for VoIP, one for IPTV, etc.
https://linustechtips.com/topic/1237034-ethernet-switch-issues/#findComment-13947671
Yeah it was from windows
https://linustechtips.com/topic/1237034-ethernet-switch-issues/#findComment-13952661
