Both my 200mm case front fans are not spinning ( cooler master h500m)
steve55
I just assembled my brand new pc and got everything up and running. But I'm having 2 seperate problems with air cooling.
the first problem is : both my 200mm front fans of the cooler master h500m are not spinning at all, I cheked BIOS and I found them detected as "system fan 2" and "system fan 3" (with "system fan 1" beeing my rear fan and "CPU fan" is obviously my cpu fan)
both of the system fan 2 and 3 are put at DC mode, 7.2 V and with smart mode turned off. And the RPM of each of the front fans is 0 while the rpm of the rear fan is around 980 and the CPU fan around 1370.
so I'm really lost and freaked out as I don't understand why both front fans are not working.
the second problem is : when I'm putting minimal stress on cpu, (for example a simple download) the cpu fan ( arctic freezer 34 esports duo ) starts doing some abnormal loud and pingy sound ( I'm not talking about how loud the sound is, I'm talking about how abnormal and strange it is, it sounds like it's gonna break at any moment)
this is saddening me, any help or suggestion would be so so appreciated ...
I'm using the msi b450 mortar max MB, the CM h500m case and as for cpu, cpu cooler, gpu : ryzen 5 3600, arctic freezer 34 esports duo, amd rx 5700 xt
The H500M has the front fan header connected to the RGB controler. Unplug it and plug it into a motherboard fan header.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
can you further explain this to me please ? what's the harm in keeping it plugged to the rgb controler ?
The 2 front fans did not work for me as well so I googled it.
I did not think much past that since it worked.
