Most of the games I play are more CPU dependent. and I am already planning on getting a 2080ti or if the new AMD or Nvidia GPU drop and they preform to there price point I may get one of them. but for now I planning on a used/open box founders edition for water cooling. My main focus for this post is CPU I would like to keep under $600 but also dont want a budget CPU. I see the Ryzen's have more cores but there clock speeds are lower then intel but I have never overclocked a Ryzen CPU so I am not sure if the head rooms there to take like a ryzen 9 3900x to say 5GhZ. or if I should go with a 10900K instead.
For games only, a 10900K or a 10600K make the most sense on the Intel side. 3700X on the AMD side.
If you have other more highly threaded workloads you can consider the 3900X or 3950X.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Might want to go with a 10900k if your strictly gaming, it will cost a hell of a lot more for the cpu and motherboard but it will be better for games.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
A 10600k doesn’t makes sense, lower single thread speed than a 3600, less cache, and you have to pay for a z490 board. Only reason it would make sense to go tenth gen is for the i9
AMD blackout rig
Just now, Letgomyleghoe said:
A 10600k doesn’t makes sense, lower single thread speed than a 3600, and you have to pay for a z490 board.
An OCed 10600K gets damn near the best FPS available today. Basically it crushes the 3600...
https://www.gamersnexus.net/hwreviews/3592-intel-i5-10600k-cpu-review-benchmarks-ryzen-5-3600-et-al
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
If you are going with next gen amd or nvidia gpu, then just go with next gen AMD cpu too, it should be a beast in gaming. R7 4800X should be a good match to your specifications.
On AMD, atleast on 3000 series, unless you are a really really good overclocker (per CCX overclocking etc), basically there is no overclocking.
You just remove the EDC, TDC and PPT limits, and let the CPU do it's thing. It will automatically run at the fastest clock possible, and use the optimal voltage while doing it. On a custom loop it will run faster than on an AIO etc.
On Intel, you overclock like normally.
If you need to buy a cpu right this instant, then Intel 10th gen I7 will be damn impressive in games.
I only see your reply if you @ me.
Im not going to spend the money to custom water cool an i5 also after going with the 5820K last go around I rather shoot for excess over value. If I was on a lower budget or didnt have plans to hard line the system then I would gladly look at the i5  then go buy a 3700X
I would get something that you don't have to swap out too often. I've seen some people's custom loops and it looks like a bitch and a half to work with.
UNLESS
.....that's what you like doing. Then get the worst CPU you can get, to force you to upgrade sooner, to get to update your custom loop sooner.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
10900K it is, then. Delivers the highest FPS vs any other CPU.
Or wait until next gen Ryzen launches to see if AMD takes the gaming crown.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
I dont base my decisions on future possible CPUs or GPU thats why I really didnt go into my the GPU that I am planning to use. Also I plan on buying this before October. Also I rather have the i9 over the i7 for the faster boost clock and more cores. I plan on keeping this system for at least 5 years
UNLESS
I have a custom hard loop system now and I can confirm it is a pain in the ass to upgrade anything
