Msi A320m pro max
Go to solution Solved by mariushm,
Also, on some motherboards, SOME usb 3 controllers are not initialized at boot, so a usb keyboard or mouse in a usb 3.0 port may not start and then no matter what key you press it won't be detected because the keyboard is not started.
Move the usb keyboard into a usb 2.0 port, those will almost always work.
Or, get a ps/2 keyboard, those pretty much always work.
F2 , F10 and DEL are the most common keys to enter BIOS.
Watch the videos I linked to.  It's a feature of Windows which sends you to BIOS after a restart. If the BIOS has UEFI features, Windows should be able to restart and "press the right key" to get the BIOS to open up for you. Try like it shows in the video.
Another thing... just disconnect the SATA cable from your hard drive, or remove the M.2 SSD from your motherboard.
Now you can keep rebooting the PC and pressing keys until you get the right key. Or, the bios will tell you "no operating systems found, press any key to retry or press THIS KEY to go in BIOS" ... or something like that.
You mind making this multiple sentences. This is impossible to understand in the current way it is written.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934577
i feel your pain bro.
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934582
Carson is in P A I N, and he clearly (doesn't) like it.
(That isn't me, that is youtuber CallMeCarson just in case you didn't know)
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934588
Just now, Sheanfabs said:
im bad at english but im trying to go bios in msi a320m pro max cant go because of no signal
No signal to monitor? Do you have a dedicated graphics card or a CPU ending with the G suffix, (as in 3200G, 2200G, 3400G, etc.). If not then you made a poor building decision by not purchasing some form of GPU. All Intel core CPUs come with an integrated GPU (unless they have the F suffix), that is not true for Ryzen. Ryzen CPUs only come with an integrated GPU if they have the G suffix.
It sounds like you can't get into BIOS bc the system has no working videol output.
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934633
22 minutes ago, Sheanfabs said:
my pc are starting up just fine but when i restart it says no signal and i was trying to go bios and then i turn it off and open again and it shows no signal again so i did was turn off directly to psu and it working fine again but i cant get to bios need help
Do you have GPU? and which CPU do you have?
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934648
i do have a gpu and my processor was ryzen 5 3600 i can restart back then and working fine and i did get into bios too just now only i cant go into bios and no signal in restart i tried to press del F1 F2 F11 F12
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934653
i have a gpu im using my computer right now if i restart this it will show no signal and if i try to turn it off and open again same no signal and i need to directly turn off it on the psu and open again so it will work and i cant still go to bios by pression F1 F2 F11 F12 or Del key
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934667
1 minute ago, mariushm said:
If you are in Windows, you can select the reboot to bios option in the start menu
See https://www.laptopmag.com/articles/access-bios-windows-10
Also
there is no uefi firmware settings in mine or maybe my recent motherboard is still saved in my hdd ?? i did not reformat or anything after installing new processor and motherboard
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934679
Have you tried to clear the CMOS by pulling the CMOS battery (a small circular battery usually on the lower half of the motherboard) out and back in?
 image.png.5f957182a162aa76b8d28fb18d210b30.pngThis is a really strange issue and your poor english isn't making this better.
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934683
no i never tried to clear that
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934700
Your UEFI firmware is saved on a chip on the motherboard, not on the HDD. You should always be able to get into BIOS even without a HDD plugged in as long as all your hardware is working and functional, and your UEFI firmware is not corrupted. I'm not going to say that your firmware is corrupted, but it is a possibility. If you do need to replace your firmware, you can download the firmware to a blank USB drive here: https://www.msi.com/Motherboard/support/A320M-A-PRO-MAX and then use a tutorial like "How to flash BIOS" to help. There may also be instructions on how to flash your BIOS in your motherboard manual.
If your power goes out during the flashing process, your motherboard is dead and is now a $100+ brick. Unplug unnecessary electronics like heaters and vacuums from any outlets in your home before you flash your motherboard. BUT DON'T flash your firmware until we have tried everything else.
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934703
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934742
workssssss thanksssss i did remove the sata and it worksss thanks alottt
https://linustechtips.com/topic/1235797-msi-a320m-pro-max/#findComment-13934763
