So after I recently repasted (using the same MX4 and a few times just to make sure it wasn't a one off where I did things incorrectly) I've noticed the difference in temperature between the cores keeps increasing over time.
So for instance immediately after repasting if I run Prime95 or playing a game I notice that temp difference between the cores is about 4-5 degrees. However after a few weeks playing the same games or running Prime95... the core temp difference increases to about 10C. This difference doesn't happen at idle when they're 2-3C apart or running light loads - only when the CPU is being stressed...
This has happened more than once.... Why does this happen? Is it a problem with the paste? My pasting methods (I've done pea size and spread evenly using a spreader)? Or does everyone see this issue?
It would be interesting to know whether the higher temp core gets more hot or lower temp core cooler, as the gap increases.
Also - what's the cooler model?
Pax vobiscum
Difference in temps is because the IHS isn't completely flat or because the paste job isn't the best or both.
What are the temps either way?
Phone: Pixel 3a (Purple-ish).
Build Log:
What @TofuHaroto said. Even most coolers don't have flat coldplates. That's why manualy spreading the paste isn't recommended. It will spread evenly without a manual spread. If it doesn't, it means there's either not enough mounting pressure or paste
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
Also... I'm not overly worried about the difference in temps (as yet). My question is... why does it increase over time.... what could be causing that?
TIMs have a curing time. Since weeks have passed, you shouldn't see any degradation from now on (till the point where the paste needs to be replaced, of course)
1 minute ago, The Rabid Crow said:
Interesting... I think the lower temps have got lower...
My assumption then is, that the thermal paste needed time to get into cracks and crevices of the IHS and cooler base. So the cooling improves?
If the higher temp cores would have gotten hotter, then cooler might be sagging and therefore hanging a bit further from the top. So the cooling worsenes.
Just a theory. There might be many other different factors at play.
Also yeah, specs would be nice.
Pax vobiscum
It's a laptop and I've tried my hardest to make sure that's not an issue... although the plate maybe imperfect as might be my technique.. I've screwed in across... slowly and tried to make sure I was doing this by applying even pressure at all sides...
Its just a thing that happens. I have the same laptop and as long as the temps don't get worse its fine.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
