Hi,
I have a full tower using 500W PSU and a Asus VZ249H 24" monitor.
Currently, I'm using a Prolink PRO701SFC UPS.(650VA)
Can this ups make any harm to the parts?(I'm asking this because my monitor recently broke and only used for about 6 months.)
Do you guys think this PSU is enough or should I get a 1200VA one.
Any thoughts on this matter will be greatly appreciated...
https://linustechtips.com/topic/1235541-selecting-a-ups/
no. should be enough to power down the system in like 5-10 minutes.
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13931966
Your current unit is Simulated Sinewave. It's a nice middle of the road feature for a UPS. You should be fine with what you have if you can save your stuff quickly and shutdown.
To answer your question as to if your UPS could harm your other hardware. It's not impossible but it's not likely either. I wouldn't worry about it.
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13931990
If it was not powerful enough it would just shut down with an overload error.
F@H
GPD Win 2
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13932012
Is it possible to give a overload error under stress like gaming or rendering? If it is possible can you suggest a software to stress test my whole setup.
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13932043
Had no problem with APC. Would always stick with them even though they aren't the cheapest by a long shot.
Intel i9-13900K - Gigabyte Aorus Z790 Elite DDR4 - Corsair Vengeance LPX 128GB DDR4 3200 C16 - Gigabyte Aorus Master RTX 4090 24GB - Corsair 4000D Airflow - 2x Samsung 980 Pro 1TB  - Corsair AX1600i 80 PLUS Titanium 1600W - Aorus FI27Q - Noctua NH-D15 running 3 fans (CPU) - 6 x NF-A12x25 (3 intake, 3 exhaust) - Aorus K1 - Aorus M5 - Aorus AMP500 - Aorus H5 - Corsair TC70 - Win 11 Pro
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13932231
6 hours ago, re4nightwing said:
Hi,
https://www.apc.com/products/runtime_for_extendedruntime.cfm?upsfamily=29
A 650VA UPS will give you 4-6 minutes of runtime at 300W draw on fully charged batteries.  (Assuming healthy batteries.)
Grab a Kill-A-Watt and see what your actual draw is, and base it on that.
https://linustechtips.com/topic/1235541-selecting-a-ups/#findComment-13933134
