Pc not posting after cpu upgrade
Go to solution Solved by Moonzy,
2 minutes ago, crazer78 said:
Thanks for saying pretty much everything I was thinking!
I was hoping i'd just missed something. I really don't want to have to deal with returning it but looks like I may have to.
keep the system as is, plop the 8600K in, check bios version
if everything seems right, plop the 9900k in, if it doesnt boot then it's fair to say it's faulty
Hi, I recently brought a i9 9900k to upgrade my i5 8600k. After replacing the cpu I can not get the pc to post.
I've updated the bios, reset to default settings and tried booting with just 1 stick of ram and no gpu but still no luck. I also put the old cpu back in and it booed up with no problems.
The new cpu is second hand but i've been assured it works so hopefully i'm just missing something.
My specs:
  • Gigabyte z370p d3 (Rev 1.0) with bois version F14
  • 4x4gb teamgroup vulcan ram
  • Reference 1080ti
  • Corsair RM850i power supply
  • Hyper x 240gb boot drive
  • seagate barracuda 2tb drive
  • WD m.2 500gb drive
Any help would be appreciated
https://linustechtips.com/topic/1235278-pc-not-posting-after-cpu-upgrade/
You flash to latest BIOS before upgrade?
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
Even if the CPU is bad, you can still RMA it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Its second hand and i have no proof of purchase?
1 minute ago, BlueScope819 said:
You bought a 9900k? These days?
The reason it doesn't work is Z370 DOESN'T SUPPORT 9TH GEN CPUS EVEN THOUGH THEY ARE THE SAME SOCKET
Yes i didn't wanna buy a new motherboard.
Its on the supported cpu list with a bios update
2 minutes ago, BlueScope819 said:
How much did you pay for the 9900k?
I know it's on the supported CPU list but it's not a Gigabyte limitation it's an Intel limitation. This is why z390 exists.
£320
I'm not sure I understand. How can it be on the supported list then?
18 minutes ago, BlueScope819 said:
you could have bought a B450 Tomahawk MAX and a Ryzen 5 3600
and is also an inferior CPU in many ways, especially gaming
there wouldn't be a reason for Z390 to exist
afaik, z390 has better VRMs averagely to deal with the 9th gen's 8 core cpus, but the z370 boards should deal with it just fine, though VRMs might need some cooling if the VRMs isnt good
as for feature differences, i think USB and wifi standards are higher? dont quote me on this
if everything works on the 8600k, but not the 9900k after a bios update, the 9900k is probably faulty
17 minutes ago, lexusgamer05 said:
There's no way this can be legal, it's essentially false advertising.
what is?
it saying 8th gen supported in the product page but supports up to 9th gen?
that's guilty of not updating their product page when 9th gen launched, at best
-sigh- feeling like I'm being too negative lately
