I would go open air. They generally run quieter and cooler.
Though depends on what cards we're talking about.
Afaik quadro's are specifically blower style to fit in certain servers.
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927875
blower GPU if your case doesnt have any fan to circulate the inner air, but have many vents (mostly small mITX cases)
as it will exhaust hot air out the back and draw in fresh air from the vents
open air cooler if your case airflow is decent
also because blower cards exhaust air, if your case airflow is setup in a negative pressure (more fans blowing out than in), their temperature may be higher as they have to work harder to move the same amount of air
though generally open air cooler have better temperature due to heatsink size
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927878
10 minutes ago, WanderingMist said:
Thx for the info.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927885
Just now, FoldingToFightAnyDiseases said:
Well I mean I am waiting for RTX 3000. 🙂
Ah, then wait and check what the reference and AIB cards will be.
And then decide.
Build Log:
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927891
Well I was thinking about using the Phanteks Enthoo EVOLV ITX TG with 1 rear 140mm fan and 2 front 140mm and a 280mm AIO on the top. Which one is best?
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927897
come to think of it, blower cards might perform better in server racks than open air designs because they rely on the front to back airflow config on most servers to blow air from 1 side of the card to the rear exhaust, like some of the fanless cards that's meant specifically for these server racks
open air cards might create too much turbulence to work well in those
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927902
Yes that was my point lol.
Just didn't want to be specific.
Build Log:
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927915
this looks horrible for either cards, not enough space between the card's fans and the red plate to draw air
but if i had to pick, probably open air given the amount of fan you'll have in the case
a blower card wont fare any better in this situation, as the case should receive a decent amount of airflow anyways
edit: i think this case is made more for watercooling, if you ask me
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927919
Well it is the cheapest ITX case while looking decent I can find in the UK.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13927977
Always prefer blower. Look better but it seems nvidia I’d going away from that.
Not a fan of high pitch fans all over my card just to reach the same temps.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13928458
Sure I will go with a open-air fan GPU if I am installing lots of fans.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13928633
5 hours ago, FoldingToFightAnyDiseases said:
But I am still having anxiety of one of the GPU fans being blocked by the PSU shroud.
It's probably the best option out of the two
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13929333
1 hour ago, FoldingToFightAnyDiseases said:
What would happen if I went for the Phanteks Enthoo EVOLV SHIFT instead?
Are there any case fan to circulate inner air?
Feels like this is worse than the one before tbh
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13930999
It is ok, I am not going to use the Phanteks, I will use the Metallic Gear Neo Mini V2 since it solves the clearance issue.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13931746
2 minutes ago, nathanyule said:
An open air would serve you best. I think the other people above me already gave reasons to why that is better than a blower card.
Yep disperses heat better. Cooler and quieter. It is good bro. I mean I just wanted to know what both is XD. I am a nooby.
https://linustechtips.com/topic/1235080-blower-or-open-air-gpu/#findComment-13932147
