Can I use old system drive on new build
PWforPower
I didnt have any problems with my windows, it is cracked or I dont know, but it isnt buyed, but no bugs, all functions... never expiries... When I first installed windows I had full windows packet and I choosed Enterprise.
Can I put ssd from this pc to new build and to normal work, only parts changed ?
you can use the drive in a new build without reinstalling. but keep in mind that this can be problematic with new hardware, especially if changing to intel from amd or vice versa, and your windows will deactivate, requiring a reactivation. not sure about the reactivating thing since it is cracked though.
I would not recommend using an installation from another PC
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
You can transfer the windows key pretty easily in 2020, just sign into a microsoft account in Account Settings and the Windows Store on your current PC. I'd recommend making a USB windows installer and doing a fresh install new SSD, keep with enterprise just incase there's key compatibility issues.
Once the new install is done, do the same sign-in process and it'll activate the PC using the previous PCs activation key.
I've been going off a Windows 7 upgrade since that was a thing and just cross-activated every device in my house.
My rig:
CPU: Ryzen 5 3600 3.6Ghz, OC'ed to 4.2Ghz all core @ 1.25v + Corsair H60 120mm AIO
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
I dont need fresh install, I want only to transfer ssd from old intel pc to new intel pc(from 1366 to 2011)
Just don't. Chipset drivers, ethernet drivers, possibly display drivers will give you issues and slow your system down due to compatibility issues. It's ALWAYS best to just do a fresh install on a new rig if you want it to preform its best.
My rig:
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
What you mean new hardware? I want to transfer from old 1366 lga to 2011 lga, but of course I had to change in near future from intel to ryzen.
Right, i didnt thinked about that
This is new hardware. It's a different rig.
My rig:
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
literally that, changing from one set of parts to another is "new hardware". again, you can use the drive without reinstall, but as everyone else has said, expect issues. if the only reason you don't want to reinstall is you don't want to deal with the windows activation, you will have to deal with that either way, so a reinstall will always be best.
But if I've have seen good, Linus only put his old ssd to new build?
They don't show every time they need to do a windows re-install on camera. They have Jake for that 😂
My rig:
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
reason is of 1tb ssd with a lot important stuffs
Just now, Chronified said:
They don't show every time they need to do a windows re-install on camera. There's Jake for that 😂
Yes i know that, but is he mad to every time install same programs and put on same place on the desktop
Just back it up
Reminder⚠️
Just now, Kanna said:
Just back it up
With last image back up I destryed system drive
You can plug your old drive into your new rig after windows is done installing on the new drive, go into disk management, assign it as the D drive and everything will show up.
My rig:
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
In short, yes you can
No you shouldn't
And practice occasional system wipe can improve your system performance by up to 10% just because of getting rid of small bugs and junks that windows update leave in your computer over time, or bloatware that you don't need anymore
-sigh- feeling like I'm being too negative lately
3 minutes ago, PWforPower said:
Just because you can doesn't mean you should
Agreeing with Moonzy, Again, like we've all said, it's VERY worth it to take the extra time to do a fresh install. It'll likely be faster than transferring your drive anyways, plus you'll have peace of mind that there aren't old drivers slowing you down.
My rig:
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
What about sysprep
Someone says safe mode than updating drives etc.
