Need help building a PC
Solved by Coconut Money Affiliates,
CPU: Intel Core i7-4820K 3.7GHz Quad-Core Processor (£227.99 @ Aria PC)
CPU Cooler: Be Quiet DARK ROCK PRO 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler (£65.96 @ Aria PC)
Motherboard: MSI X79A-GD45 Plus ATX LGA2011 Motherboard (£134.99 @ Aria PC)
Memory: Corsair Vengeance LP 32GB (4 x 8GB) DDR3-1600 Memory (£220.99 @ Dabs)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk (£47.99 @ Aria PC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£54.98 @ Aria PC)
Video Card: Zotac GeForce GTX 780 3GB Video Card (2-Way SLI) (£382.34 @ Ebuyer)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case (£79.99 @ Amazon UK)
Power Supply: XFX 850W 80+ Bronze Certified Semi-Modular ATX Power Supply (£86.21 @ Aria PC)
Total: £1683.78
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-04 18:33 GMT+0000)
4x4 for Quad Channel RAM, if you want it faster, OC in the BiOS. I chose reference cards because they are nicer looking, and for 2x GPU setups they are better for temperature. The Dark Rock Pro 3 will be dead silent and cool. The 4820K is the same as the 4770K, but it is X79 allowing for Quad Channel RAM. SSD for OS and everything else on the HDD plus you can reuse your old HDD for even more storage. Hope I helped
