DAC/Amp Recommendation or Need?
For Science!
Hello!
Similar to the thread below, but I wanted to hear (hahaa) your opinion and recommendations for DAC/Amps. I am using a HiFiMan Sundara as my headphones, and both on my PC and mobile phone (Galaxy S7) I need close to 100% volume to get good volume. I am interested in both a desktop solution and something that can travel and be used with my phone. If there is a particular product that works well on the desktop as well as on-the-go, that would be the best option for me as I Ideally don't want to buy two. If you think the audio quality will not change though I need 100% on my devices, also good to hear that too.
No real budget, but lets say ideally around the <200 USD range (I am in Germany)
Ifi hip dac.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
5 hours ago, Tigerleon said:
Ifi hip dac.
1 hour ago, rice guru said:
ttopping l30 and   A topping d10 would be pretty decent
Can I interpret that your recommendations indicate that I will benefit from having an extra device for audio quality?
with the sundaras definitely thiose are already headphones that punch above it's own weight class and will only benefit from a cleaner more powerful source
