not sure if this was supposed to be in the gpu section, sorry!
so i recently came into possession of a 980ti, and after much troubleshooting it seems that the original fans don't work. so i ziptied the stock case fans that came with my meshify onto the radiator and set them to max speed (1200 rpm) and it appears to work fine. despite this crazy mofo of a card pulling 360 watts it won't go over 76C in furmark.
in comparison, i have a d15s on my 9700k and for testing purposes i put an extra corsair ml120 on the intake end at full speed (2000 rpm) and tested my overclock in p95. 4.8 ghz with avx on pulls 200-220 watts and gets above 95C before i get worried and stop it.
so how can the 980ti cool itself so much better than my cpu? im using TG kryonaut on both but even if i were to delid the 9700k and use LM with a direct die frame i wouldn't expect to drop my temps by 20C and it's pulling 2/3rds the wattage. i've got an evga 1080ti ftw3 coming in today or tomorrow which i'll be testing, iirc it has a hard limit of 250w so i wonder if it'll run much cooler than the 980ti. for reference the 980ti is a gigabyte xtreme windforce, which appears to have two 120mm radiators with those oversized 12mm heat pipes.
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1233994-heat-dissipation-on-cpu-vs-gpu/
Couple things. First, the 980ti has a much larger die, so the heat is spread out more. Second, the CPU has several extra layers of heat transfer because of the IHS (integrated heat spreader). For the 980ti it's die->thermal ccompound->cooler->Air where-as for the CPU it is Die->thermal compound->IHS->thermal compound->cooler->Air. Finally the die on the 980ti isn't consuming all of that power, the memory and VRM efficiency also have to be accounted for.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
looking at gpu-z the chip is pulling 300w (dunno about vrm losses) and the memory is pulling 60w. how about with other gpus? i know that a lot of navi cards run really hot, my buddy's 5700xt's junction temps are over 90C and that card doesnt use over 220w afaik
It's all cooler design and die density. I just upgraded my 5700xt cooler + liquid metal recently and dropped temps a ton.
Delid and liquid metal would help your CPU a lot. Also, prime95 is not a realistic load. Fine for stress test and stability, but you'll never see that in actual use. Unless you are using prime95 for it's intended purpose every day.
You are overclocking, and probably increasing voltage, and then hitting it with the hardest load you can. Its going to get HOT when you run it outside of design parameters. Temp (wattage of chip) increase is not linear with voltage and clocks, it's an exponential curve.
Overclocking isn't just about finding stability at the highest clocks, it's about managing heat too. And often that's the limiting factor.
oh yeah i'm aware of all that. i run half the cores on PRPs 24/7 cause they recently made it self checking so it's great for memtesting which i've been doing a lot of. i prefer to push my hardware with an "unrealistic" load as i dont want any stability issues. could do 5.1ghz for games without too much heat but it wouldnt handle p95 well. i wouldnt wanna run a system thats only stable if youre not utilizing its full power.
mb forgot to tag you
Are you having memory issues or working a new RAM OC? Why test constantly?
I understand wanting to be stable, you are just at the limits of your hardware, heat wise, with the work you are doing.
Back to the original post though, it's normal for CPUs to be hotter than GPUs with equivalent power draw for all of the reasons @hairlessmonkeyboy said.
been building a new system for a few weeks now and i've been working on OCs for several different kits. i also just contribute to GIMPS regularly.
