USB Hub
Go to solution Solved by SupaKomputa,
3 minutes ago, Drew Learns Tech said:
I had my mic (yeti pro), webcam (some old logitech one), my mouse (newer logitech one, and my DAC (Fulla 2). My guess I ran into both data and power issues.
All of that can use a single usb3 bandwidth.
The problem is when the device rely on the usb to power it on.
To solve this you can get a active usb hubs, the one with it's own adapter.
I've recently moved my computer and I can't get all of my usb cables to my computer. I tried using a standard usb hub that I already had but it overloaded the usb connections using so many high need devices in a 4 port going into only 1 port. Linus has shown in the past that he can use thunderbolt to solve this problem. I don't have thunderbolt though so is there any solution or do I just have to buy extender cables and suck it up? Thanks!
https://linustechtips.com/topic/1232922-usb-hub/
If you have some money there is thunderbolt pcie cards keep in mind I’m not sure if it works if mobo doesn’t support (someone have to verify that for me)
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910206
there are USB3.0 ports if you're running into bandwidth limitations (unless you're runing into THAT limitation then idk)
im using a 7 port USB 3.0 hub, there are hubs with more than 4 ports
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910210
I'm running into bandwidth limitations yes, I tried mine and it just kept on jumping from device to device trying to run them all.
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910218
1 minute ago, Skipple said:
You are either running into two issues:
  • A data issue
  • A power delivery issue.
What do you have plugged into it? That will more than likely tell you which it is so we can recommend you a solution.
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910225
I looked into those a few year ago they mostly were only on the intel HEDT series mobos which I dont have
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910229
hmm this shouldnt saturate a 3.0 link, maybe a 3.0 hub would help? or you're already using one
personally using 2.0 connection (on a 3.0 hub, coz i dont have 3.0 extension yet) for very similar setup, minus the DAC
havent had any issues even with my webcam transmiting 720p60 footage (logitech c922)
i recommend getting a powered hub btw
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910233
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910243
I just swapped to a different usb extension and it seems to be working now but I'll look into one of those for a better long term solution
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910252
Yeah, some usb hubs are just poorly made.
Powered hubs are always better, as it remove the stress on the usb port.
https://linustechtips.com/topic/1232922-usb-hub/#findComment-13910263
