Maybe a 1660 Super, tbh anything at this price is way below what the 3700X can power.
Desktop benching:
https://linustechtips.com/topic/1232877-graphics-card-help/#findComment-13909661
Is this for gaming
If it is, you overspent on the CPU.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1232877-graphics-card-help/#findComment-13909662
10 hours ago, james-_- said:
about 250$ range
new: 1660 super or a 5600xt for a little more.
used: 1070/ti/1080.
if you're mainly gaming and you can return the cpu, get a 3600 and a better gpu.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1232877-graphics-card-help/#findComment-13909691
