So I recently bought a powerline adapter (tplink av2000) and it came in today. I was setting it up and now i'm using it on a minecraft server, and its mostly fine, but I randomly get lag spikes (up to 2000ms) and they last like 20 seconds. I also sometimes get randomly disconnected. Please help! (and I appreciate it in advance!)
I have a 5800x and a 3070
https://linustechtips.com/topic/1232581-help-with-powerline/
Powerline's reliability is entirely dependent on the quality of electrical wiring in your house. If your wiring sucks, powerline will suck.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1232581-help-with-powerline/#findComment-13907443
@PorkishPigok thank you for the reply, my house was built in the 70's, so that would make sense. So do you think it would be better for me to just buy a good pci-e wifi card, because I can still return the powerline adapter.
https://linustechtips.com/topic/1232581-help-with-powerline/#findComment-13907463
8 minutes ago, sssolar said:
  Reveal hidden contents
WiFi could be just as bad. Servers need to be wired in to the router.
https://linustechtips.com/topic/1232581-help-with-powerline/#findComment-13907473
Yep, that's really your only other option. I used a TP-Link Archer T9E for years, excellent card. T6E performs about the same. If you're looking to run a server, I would suggest looking into re-purposing an old desktop as a headless server that you can connect directly to the router.
Desktop
Homelab
https://linustechtips.com/topic/1232581-help-with-powerline/#findComment-13907493
