I don't know anything about TV mounts but I plan on installing one for my TV, I have a Sanyo DP42d24 (42 Inch) and was wondering if the TV mount I found would be compatible.
https://www.amazon.com/PERLESMITH-Motion-Bracket-Swivel-Extends/dp/B07K6CQGSV/ref=sr_1_6?crid=PHJOBPM9AAPY&dchild=1&keywords=wall+mount+200x200&qid=1597010686&sprefix=wall+mount+200+%2Caps%2C170&sr=8-6
Any other TV mount suggestion would be awesome!
https://linustechtips.com/topic/1232554-tv-mount-help/
That should work yes, your TV requires a VESA 200x200 mount and that's what that is.  Either the TV, and/or the mount, should include the required M6 screws.
https://linustechtips.com/topic/1232554-tv-mount-help/#findComment-13907204
shoot, I have the TV for awhile now so I won't have the m6 screws.
https://linustechtips.com/topic/1232554-tv-mount-help/#findComment-13907210
Buying one from amazon you could buy both.  Seems there are “tv mounting kits” with bunches of screws in varying lengths and sizes along with washers.  Maybe don’t open it and see if they come with the mount first so you can return it if you don’t use it.
https://linustechtips.com/topic/1232554-tv-mount-help/#findComment-13907231
Look up the TVs manual online. Maybe it will provide you with screw size. But in my experience many mounts come with screws.
https://linustechtips.com/topic/1232554-tv-mount-help/#findComment-13908990
