So my case has 2 internal USB 3.0 cables with connectors but my MoBo only has one to acomodate.
What to do?
i'm loosing 2 USB 3.0 ports of the case.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1232487-usb-30-internal-hub/
Just now, Moonzy said:
you could also use USB 2.0 to 3.0 internal header to run the other two 3.0 ports
but only at 2.0 speeds
I need usb 3.0 speed.
https://linustechtips.com/topic/1232487-usb-30-internal-hub/#findComment-13906526
You'll need a internal pci usb3.0 expansion card, example
https://www.amazon.co.uk/KKmoon-Express-Controller-Internal-Connector/dp/B074TGDN46/ref=zg_bs_430534031_1?_encoding=UTF8&psc=1&refRID=N0A9Z2VC646384B1MCT3
Or use a usb3.0 external hub for more usb3.0 ports.
https://linustechtips.com/topic/1232487-usb-30-internal-hub/#findComment-13906551
Can you give me example of such hubs...some models?
https://linustechtips.com/topic/1232487-usb-30-internal-hub/#findComment-13906564
Such as I have this one stuck under my desk for quickly connecting G920, xbox one controller and external usb drive when need
https://www.amazon.co.uk/Sabrent-4-Port-Individual-Switches-HB-UM43/dp/B00JX1ZS5O/ref=zg_bs_430443031_1?_encoding=UTF8&psc=1&refRID=VAN999MVX6KF9QTEAVYN
https://linustechtips.com/topic/1232487-usb-30-internal-hub/#findComment-13906594
