You can use PCPartPicker to look up the components you want. It should give you a rough idea of price, by looking up the cheapest seller. You can obviously buy all the parts from the same retailer, it might just be a bit more expensive (or less, since you only have to pay for shipping once).
If you want others to help you with recommendations then you should probably mention what you're planning to do with the system, e.g. gaming, streaming, work, etc.
https://linustechtips.com/topic/1232095-help/#findComment-13903383
Welcome to the forums!
please fill in the form, it was made for a reason :D
Quote
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):聽
also if you are planning to spend this much on the PC only, its best to wait for newer hardware like zen 3, ampere, and big navi in just a couple months time.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb聽RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430聽
Cooler Master MH聽752
https://linustechtips.com/topic/1232095-help/#findComment-13903397
7 hours ago, Adiza said:
It be mostly for gaming sorry for not mentioning that聽
Do you need it now or could you wait a few months? New CPUs and GPUs are coming out soon so it is best to wait until then to buy and build.
I am far from an expert in this so please correct me if I鈥檓 wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1232095-help/#findComment-13904420
