2080 TI power limits
Go to solution Solved by Jurrunio,
None can go below 50%, which means 125w minimum.
Tbh you could just have 1 profile with both core and memory clock sliders all the way to the left, that should drop performance and power draw to the floor. In this case the BIOS should focus on having the highest power limit instead
Is there anyway to remove power limits on 2080 TI cards?
Is there any specific model from a specific vendor has unlocked limits from 80 watts to 500 watts out of the box or any known model that has been bios moded by the community and can limit power less than 50%
I would like to buy one that I can freely adjust power limits depending on power availability.
https://linustechtips.com/topic/1231383-2080-ti-power-limits/
Not without BIOS or shunt mods. I don't even know if shunt mods still work.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13897799
1 minute ago, Islam Ghunym said:
Shunt mod works only to increase power not to cut it down, right?
Shunt mods trick the GPU into thinking it's drawing less power than it actually is.
You can still drop the core clock or voltage if you want to lower power usage.
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13897872
The problem is that I can't do that myself and can't trust anybody I know to do it for me.
it would be more clean if I got a moded bios. Nvidia bios in encrypted yeah, but if there is any case that anybody could teleport stuff from cryptocurency 2080 ti if it exists to another specific card from a vendor or whatever. That would help.
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13897889
Desktop benching:
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13897972
The reason why I like AMD that it is not a rude company decrypting bioses or locking processors like other 2 teams...
I wish all good for the company to hopefully crush NVIDIA and Intel one day.
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13899201
Uhm, that's bad. History repeats itself, AMD will do the same eventually.
And AMD does encrypt their BIOS on graphics cards as well.
Desktop benching:
https://linustechtips.com/topic/1231383-2080-ti-power-limits/#findComment-13899774
