Will more ram help cpu usage
Go to solution Solved by Tan3l6,
Yeah, adding more ram probably won't lower CPU usage. Often people are more concerned about games not using 100% CPU ..
Switching to dual channel RAM , either 2x4 or 2x8 GB, would improve the performance a bit, but not too much.
My pc is:
I5 6500
1x8 gb ram 2133mhz
gtx 10603gb (I am playing esport titles 720p and everything on low )
MSI B150m pro vdh motherboard
Recently a couple of friends got me into comp fortnite (yeah I know fortnite ) and I can't even get consistent 100 fps at 720p everything low .
My cpu is always around 95 - 100 % and my fps is going from 100 - 60 sometimes even lower which makes the game unplayable .
I don't have the opportunity to build a new pc so I was wondering if more ram is going to help .
https://linustechtips.com/topic/1229939-will-more-ram-help-cpu-usage/
Pax vobiscum
running dual channel may give you more performance, though i doubt it will help with CPU usage.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
