Rainbow six siege blue screen crash help.
Game_on
Go to solution Solved by Applefreak,
Excellent.
Hello good afternoon everyone. I'm getting blue screen error messages when opening Rainbow six siege the anti cheat software starts to validate and check my system shortly after my pc crashes to a blue screen error message any one having the same issue ? any help would be appreciated thank you all in advance.
seems like I fixed the issue it was either cam monitoring software or my 4.8 ghz oc I have finally got it to work by ending tasks in task manager for cam monitoring software and by down clocking my cpu from 4.8 ghz to 4.7 ghz did the trick.
Turned out to be the 4.8 ghz overclock because I started the cam monitoring software again to check my fps in game and no issues I guess that in some games it was just not stable or simply not a stable overclock to begin with thank you for taking interest in my post @Applefreak
