300w PSU for Core2Duo and 6970
Coswar
I am trying to frankenstein together some old parts- and wanted to see if an old Dell Inspiron 530 would work as a folding/mining rig with my HD 6970. I have ordered SATA to PCIE power adapters- so I wanna see if I should cancel them.
According to the eXtreme Power supply calculator I'll need a min of 341w, but what do you guys think? I think it might be ok, in light of TTL's recent video. Oh and there will be one HDD, no DVD or any other extras.The GPU won't even be used for screen viewing- I'll RDP in. Thanks
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
No way. HD6970 is hungry. So are core duos. And your psu won't be 300w platinum so no way man. Even if you manage to run it, it will die fast on 90% load all the time.
nope i would try
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
Argh.......Damn. I hate having parts lying around doing nothing.
Main Rig:
Home Server:
Nope, I had a 6970 and that card is really power hungry. I would spare 250W just for it. You will need at least a 450W PSU as minimum, maybe even a 500W one.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
Yeah, if it's not constantly idling, you should get 400W for this CPU+GPU combo. Unless your product is s a really high-end PSU that can manage more than one it's rated for.
