My cousin is looking to play mine craft at all max settings with lots of mods. They are trying to get a prebuilt computer and they are trying to save money by not getting a discrete graphics card. What would be the best prebuilt computer under $700 (without peripherals) with a solid cpu strong enough to handle minecraft on max with mods? If you can squeeze in a discrete graphics card that is worth the money that would be great. Links would be wonderful.
https://linustechtips.com/topic/122946-help-with-choosing-budget-cpu/
Maybe a Kaveri A10 or A8 and an A88X mobo?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
With 700$ you can easily fit a more than decent discrete GPU. Check out Austin Evan's build, it's right around your budget:
https://www.youtube.com/watch?v=43pXorOZ3MQ
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
dam that is nice but they dont know how to built computers and wont let me.......
So they're looking for a prebuilt with no GPU?
Well that sounds stupid.
Just go tell them now that they might as well throw 700 dollars out the window because they wont be happy with it and wont get the performance they want or are capable of getting with 700 dollars.
They come to you for help and doesn't want you to build one? Why not?
their last computer was from 2001
they will be happy with anything
The only time I would not recommend even getting a dedicated GPU is if the CPU was a high-end i7 with Iris Pro graphics. Tell them to get a Kaveri A10 or A8 with a nice A88X mobo.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
i havent built i pc yet
Everyone starts somewhere.
In that case, all you need is a ssd to wow them.  B)
