I've got the Asus Prime B550M-k and R5-3600, with the rx580. I'm getting orange lights on the bottom (implying it is relieving power). But I'm not posting (GPU white light is on), neither are Keyboard/Mouse reviving power. Am I missing something? First time building a PC any help greatly appreciated.
https://linustechtips.com/topic/1229245-no-post/
3 minutes ago, athesomeone said:
Didn't wire up the the front panel, since I'm testing post from them motherboard case lmao, do I need to do that?
Well you at least need to short the two front panel power pins so it boots :)
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1229245-no-post/#findComment-13879825
Just now, athesomeone said:
I shorted it with my screwdriver?
Ok, well if you shorted the right pins then you're good and it should have booted. I don't see a speaker on that board (I don't think Asus puts it on the board) so you won't get a beep code but your mouse/keyboard (assuming it's all hooked up right) should have gotten power.
I guess now it's down to posting a picture of the setup just to see if we see anything missing a cable or something :)
Prior Build Log/PC:
https://linustechtips.com/topic/1229245-no-post/#findComment-13879845
1 hour ago, athesomeone said:
-snip-
@Lurick
Hmmm, it definitely looks all connected so I'm at a loss now.
Maybe shift the ram to the second from the CPU? I can't remember off hand now.
Prior Build Log/PC:
https://linustechtips.com/topic/1229245-no-post/#findComment-13880238
