phone for 4+ years Keep a device functional for years
Solved by EL02,
It really is up to you. What I would do is get two midrangers every two years for the price of a flagship. What I think are the biggest benefits going this route are:
- No significant drops in battery life, because you're changing the phone after only two years of use.
- Lower repair costs: if you happen to crack your display, you don't have to immediately fix it as you're gonna get a new one anyway.
- New technologies. E.g people who bought their phones before 2018 didnt know ultra wide would later be a trend, or that amoled displays would almost become a norm in the $400+ devices.
- Up to date software.
- A midrange processor usually is on par with a two year old flagship one.
1 hour ago, mariushm said:I personally am looking at buying a Xiaomi Redmi 8 for under 200$, which gets me almost all that i need (64gb memory, 4 gb ram, decent camera, good battery, maybe a bit small resolution screen but i can live with it)
I would strongly recommend a redmi 9, note 8/pro.
