I bought a pretty old BenQ monitor (XL2411T 2012) that can run 120hz and maybe even 144hz? The guy who sent me the monitor only game me a HDMI cable which does not allow me to reach anything above 60hz, so I used my own DVI cable (Yes its dual link) and all I get is a distorted and blurry screen on anything above 60hz with a message that says "Use the DVI Dual link cable that came with the monitor" can anyone recommend me a DVI cable that will work? I've read that CPO, BENFEI, Cable Matters and AmazonBasics DVI Cables work but some reviews say otherwise, please I really need help
TL;DR: What DVI Cable should I get for my XL2411T? (Don't have DisplayPort)
https://linustechtips.com/topic/1228998-dvi-problem/
https://www.amazon.com/dp/B009WA4EBU/
https://linustechtips.com/topic/1228998-dvi-problem/#findComment-13877830
