So I watched a YouTube video today showing off a crazy water cooling build, I have the same case in the video the Phanteks Enthoo Pro 2 and I've been desperately trying to figure out which distro plate is used in the video, it seems the one in the video has been custom painted but it fits so nicely in the case! Any help to identify it would be amazing!
https://linustechtips.com/topic/1228997-help-identifying-this-distro-plate/
While I don't know which model it is, I'm pretty sure that it's a generic 120x480mm distro plate. What seems to be kinda uncommon, though, is that the distro plate doesn't serve as the reservoir and probably doesn't have a pump attached to it.
Dont see a distro plate. Thats custom with just pass through fittings. Nothing dancy. How most of those builds are done. Especially before the new rgb craze aka distro plates.
↑yup, looks like bulkhead fittings to me.
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
If u really want a distro plate and cant find one for ur specific case thats mass produced, they are not hard to make for someone with a CnC machine, or even a basic mill (so long as its a simple design).
See if u cant find som1 in ur local area with one, im sure u can work out a deal.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
