Yesterday I was playing a game when my pc crashed, or I thought so. After a bit and the pc wouldn't show any sign of life, I tried turning it on. Nothing happened so I tried removing the cable, turning off the psu, and even got my friend to try and help me. Nothing seemed to work, so I brought it to my friends dad who built it for us. We tested the psu, and that wasn't the problem. We figured that I must have overclocked or overused the pc. For some further info, I was running an extremely inconsistent fps of about mid - high 100 to low 200 with max settings on valorant.
SPECS:
CX750M PSU
GTX780 Ti
16gb RAM
240 gb hard drive
ASUS z97 - ar motherboard
i7 4790k.
Windows 10.
some cooler master cpu cooler.
Is there some sort of fix that doesn't involve spending money or do I have to replace the motherboard and the cpu? I was thinking about getting new parts anyways.
If there is anything else you need to know just ask and I will try my best to answer your questions. thanks.
https://linustechtips.com/topic/1228911-help-pc-wont-boot/
10 hours ago, BlueScope819 said:
at least credit the creator of the thread by linking it.
clear the cmos, try with one stick at a time, try booting with the igpu.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228911-help-pc-wont-boot/#findComment-13877046
