Buying power supply before ampere coming out
Fzero
So my problem is that I was planing on buying all the parts for my new pc this august build it when im back for school on semptember 1st and use everything new except my gtx 1070ti while i wait for ampere cards to come out. Now  i have almost everything i need for my pc except the biggest question the psu i was planing buying corsair hx1000i for my practically all corsair build but now since the news came out about ampere using new 12 pin connector i dont know if i should wait for new power supplies with that connector and spend more money or get it cheaper now and risk not being compatible?
My understanding is the 12-pin connector is purely internal testing at this point.
It's also my understanding that there will be a 6+6 adapter that will be included, when/if it's implemented.
That said, without knowing the rest of your build, I find it unlikely at best that you're in a situation where you need a 1k unit.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
Didn't the author of that article say that the 12 pin is just a joke?
Don't worry about it. Even if the 12 pin ended up being real, they'll probably include some sort of adapter or something. I doubt every consumer will end up being forced to buy a new PSU for ampere.
Phone: Pixel 3a (Purple-ish).
Build Log:
The most recent news I have on it is from 15 days ago, says that it's very much a thing that has been submitted for validation, but has not been approved at this point in time, nor has it been expressly stated as anything but internal testing.
https://www.tomshardware.com/news/nvidia-ampere-graphics-cards-may-use-new-12-pin-pcie-power-connector
If there's new information on it (which is entirely possible), I've not seen it.
This. Plus the same article also says, that it is not sure that AIB partners even have to follow it. I personally wouldn't worry about the connectors at the moment.
Quote
At the moment, it's uncertain if the 12-pin PCIe power connector will be exclusive to Nvidia's Founders Edition models or the same for all aftermarket models. At any rate, we shouldn't be despair since the PCI-SIG group might not even approve the 12-pin PCIe power connector.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
if that's the case won't the adapter limit power delivery and lower the possible overclock or is it practically negligible?
i dont see why it would tbh.
Build Log:
