So I wanted to take off amd's ram speed lock as I was adviced by a friend so I went to The bios and found something which looked like it would work and now my pc turns onn but external devices like my keyboard light up and Theres no display whatsoever so I need to know what can I do
Setup
Amd ryzen 7 3800x
Ram patriot viper ddr4 3200mhz 2x8gb kit
Nvidia rtx 2060
Msi b450m pro-vhd max
https://linustechtips.com/topic/1228549-i-need-some-help/
So you turned in XMP or DOCP and now it won't output?
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873835
Just clear your CMOS, there is usually a button or jumper for this, consult your mobo manual.
Alternatively, you can power down the system and take out the coin cell battery from the motherboard, wait 15-30 seconds and pop it back in. That will reset the BIOS to the default settings.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873839
Clear the CMOS.
Did you enable XMP or just set the frequency to 3200MHz?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873852
7 minutes ago, Max11 said:
I have only set The freuqency to 3200mhz
welcome to the forum, remember to quote or mention the people you're replying to so they'll get a notification for the reply
@Slottr @Mateyyy @GOTSpectrum
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873882
After clearing the CMOS you could look at the QVL for your motherboard to see what speed they have your RAM kit certified too.
Enabling XMP/DOCP may help the RAM run at the correct speed without causing stability issues.
My knowledge of 3rd gen Ryzen is limited, but on my 1700 I needed to tweak the SOC voltage and also the DRAM voltage to get my 3400mhz speed running correctly.
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873896
22 minutes ago, Max11 said:
what can I do
So xmp/ docp didn't work?
Clear the cmos. Then, set the soc to 1.1 and dram to 1.35. Set it to 3200 with xmp/docp enabled. If it boots use memtest86 or/ and OCCT to make sure it's stable.
Btw. Make sure your ram is in slot 2 and 4.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228549-i-need-some-help/#findComment-13873900
