Help
Go to solution Solved by Haro,
3 minutes ago, eeeee1 said:
a 500w 80+
Efficiency is not quality.
5 minutes ago, Hammerhedd666 said:
how many watts do i need to power this thing 10 hours a day?
A decent 550w unit. A budget one like a cx550 should be decent.
Or a straight Power 11 500w.
I have a computer with
AMD Phenom II X4 925 @3.2 Ghz (95w),
2x4Gb kingston ddr2 ram,
Asus m2a mx mobo,
500gb hdd
and Asus Strix R9 380 Oc edition 2gb gpu
(My generic brand 2 months old 450w just exploded today 1 hour after changing my gpu from gt710 to r9 380)
https://linustechtips.com/topic/1228540-help/
a 500w 80+ should be pretty comfortable if you ask me
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1228540-help/#findComment-13873722
Exploded? Got photos of it? I want to see what happened to it. :D
https://linustechtips.com/topic/1228540-help/#findComment-13873731
Look for a CX550 (not the old green label CX500/600, but the new 2017 grey label model).
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1228540-help/#findComment-13873739
a 500w 80+
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228540-help/#findComment-13873740
19 minutes ago, Mateyyy said:
Look for a CX550
I love the cx line. I usually recommend it. But it's overpriced at the moment. OPs whole system is worth $150 max.
Get this:
https://www.amazon.com/dp/B07NWZQX1J/ref=cm_sw_r_cp_apa_i_DUUiFbHTGFRZP
Don't be scared by the Apevia name. It's actually a decent andyson unit. The CX is better but you need a real budget unit for your setup. Unless you plan on moving it to a new system soon.
https://linustechtips.com/topic/1228540-help/#findComment-13873808
Get this:
I mean, it depends on where OP's going to purchase the PSU from. In the UK for example the CX450 is available at near MSRP. (the CX550 is a little overpriced but the TX550M is available at its regular price)
Of course, there are other options too, like the be quiet! Pure Power 10/11, System Power 9, EVGA B3, or even an older decent unit like a Pure Power L8 530W/630W.
https://linustechtips.com/topic/1228540-help/#findComment-13873838
I don't know why I assumed that Op was in the US. I must have been looking at something else.
msrp is still overpriced though. I remember buying a cx 550 for $25 after rebate lol.
Given the choice though overpriced PSUs are much better than overpriced GPUs and CPUs so can't really complain.
https://linustechtips.com/topic/1228540-help/#findComment-13873863
Depends where OP lives.  And the cx is not the only option really. There are other like the system power 9 or the straight power 11/10.
Build Log:
https://linustechtips.com/topic/1228540-help/#findComment-13873865
Just now, Hammerhedd666 said:
there is a 500 w 80+ psu + case combo.
First of all. Efficiency is not quality. Second of all there are almost no PSUs that are decent that come with a case. Don't cheap out on one. Something cheap but won't explode.
Cv550.
Vs550.
Something better.
MWE bronze V2.
Something good and is a decent budget option.
Cx550.
Build Log:
https://linustechtips.com/topic/1228540-help/#findComment-13874079
Cv550.
Vs550.
Something better.
MWE bronze V2.
Cx550.
So, I found a "Cooler Master MWE 550 80+ White". I know Cooler Master is a really good brand when it comes to making cases, cpu coolers, etc. but I'm not familiar with their power supplies. Are they any good?
https://linustechtips.com/topic/1228540-help/#findComment-13874484
Are they any good?
Just like any brand. They make good and bad units.
If that's the MWE v2. Not the worse thing in all honesty. Would still run something better with a 380 but it Technically does the job.
Build Log:
https://linustechtips.com/topic/1228540-help/#findComment-13874486
Unfortunately, I live in Turkey and even the low quality ones cost about 45 usd.
(There is a tax for nearly everything here because (not to get political) "The Tall Man" needs money.)
https://linustechtips.com/topic/1228540-help/#findComment-13877334
3 hours ago, Hammerhedd666 said:
I will take some pictures for you in 3 days but there is nothing to see on the outside. I think the capacitors exploded
Shine a light in to the PSU and look through the fan grill or exhaust grill and see if you can see anything that looks burnt. If you can try and take a photo of the area through the fan grill.
https://linustechtips.com/topic/1228540-help/#findComment-13877918
IMG_20200803_111255.thumb.jpg.a819be0e0680c9e6bd3072d57a37ce52.jpgIMG_20200803_111245.thumb.jpg.c2d5d49b100e0167e8f320b7763cbdb4.jpgIMG_20200803_111236.thumb.jpg.8c06394af70bb17fe00fa0796e8a3ec7.jpgIMG_20200803_111222.thumb.jpg.e8fe9d0cff680642c52337f98c84d243.jpg
There is a couple of dings here and there (which I don't know what caused them) but I was surprised to see none of the capacitors were exploded. Then I saw a broken fuse (I thought this psu didn't have one).
https://linustechtips.com/topic/1228540-help/#findComment-13892415
Thanks for the pics. That PSU is a piece of junk (but you probably didn't need me to tell you that xD).
Have you bought a new PSU yet or are you still looking?
https://linustechtips.com/topic/1228540-help/#findComment-13892465
17 minutes ago, Hammerhedd666 said:
No, I haven't bought one yet but I think I will buy Cooler Master MWE 550 80+ White V2
Much better than what you previously had.
Are you planning on keeping the Phenom II system or are you upgrading it?
https://linustechtips.com/topic/1228540-help/#findComment-13892554
I'm thinking about uprading to Ryzen or FX next summer and I changed my mind and bought a Cooler Master Elite 600 v3
because it was on sale.
https://linustechtips.com/topic/1228540-help/#findComment-13902144
