So I had just built my new pc and I am running into some trouble. I am currently (and temporarily) using my old pc's cpu which is an i5 7600 (cooled with a corsair h100i rgb platinum) with a new motherboard that is the Aorus Z390 Pro along with a corsair RM850x psu. For some reason, the cpu light on the bottom right of my MB is red and I believe it may be something to do with the cpu compatibility of the MB. The box and manual says the MB supports only 8th and 9th gen intel processors which I can safely assume rules out the compatibility with an i5 7600. Has anyone else had this problem that can confirm the issue? I am going to have to buy a new cpu i suppose
https://linustechtips.com/topic/1228435-red-cpu-light-on-mb/
kaby lake does not work with z390.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228435-red-cpu-light-on-mb/#findComment-13872882
Just now, lance.m said:
this should be okay right?
Yup.
Build Log:
https://linustechtips.com/topic/1228435-red-cpu-light-on-mb/#findComment-13876220
