specs?
and what?
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
Just now, Lamont-Dragon said:
Ga -7170x-gaming 5 putting in a 17 7700k
Have you updated the BIOS before installing the new CPU?
10 hours ago, Lamont-Dragon said:
Should I swap back how would I check that ?
yea, wont hurt to do so. and make sure the bios is updated.
Build Log:
is it a z170 chipset? you'll need a bios update to support 7000 cpu if thats the case
you'll need a 6000 series cpu to do that, unless your motherboard have bios flash feature
-sigh- feeling like I'm being too negative lately
9 minutes ago, Lamont-Dragon said:
They should have been up to date ? Should I swap back how would I check that ?
If you haven't updated the BIOS -> your board has a BIOS currently incompatible with the i7 7700K
Place back your old CPU and update the BIOS.
3 minutes ago, Lamont-Dragon said:
I had a 15 6600k
Keep in mind it's Z170, not 7170. It's i7 7700K, not 17 7700K. It's not 15 6600K, it's i5 6600K.
From context I was able to tell what you meant; but with Googling and such it's easier to have the correct wording (since you have to look up your motherboard to download the newest BIOS, for example).
Yeah I'm bad with typos sorry
Doesn't bother me at all; your post was very readible. It was more of a 'heads up', since Googling would be more difficult without the proper names
7 minutes ago, Lamont-Dragon said:
Now it's trying to do a automatic repair
Is Windows doing an auto repair?
It shows the bios page but right after starts auto repair but gets stuck
Could you take a picture of the screen it's getting stuck on?
Was your Windows working fine beforehand?
Normally this shouldn't happen because of a CPU swap.
If you press Advanced Options > Continue, does that throw you back into the same loop?
Windows was working great before
Idk why it's doing this now
  • 3 months later...
