Power going out during PC usage
I'd hate to be premature about this, but I think I've solved the problem.
After talking with an electrician he suggested I get a breaker replacement for my room, but he mentioned something else that caught my attention. He said that the type of breaker I had in my house (AFCI) are meant to be finicky and preemptively trip if it detects a fire could be caused. This is usually due to wires being too small for their appliance, or just faulty/poorly managed power bars and stuff. While I was paying all my attention to my PC hardware for potential flaws, I didn't pay any mind to my monitor. In contacting steam support, they said they didn't have any advice for me other than sometimes the monitor can cause surges when switching between resolutions and refresh rates often. So what I remembered was when I recently bought a higher resolution monitor, I neglected to use the original power cable that came with it, instead using the power cable for my old monitor. After switching the power cables and running DOTA for an extended period of time, recreating all of my prior steps, I have not run into any issues so far. If I don't have any issues after more time I will consider this case closed. This solution makes sense to me because even though it would happen CONSISTENTLY in DOTA, it would still happen sometimes in other applications as well. This could be because DOTA would always cause the same type of power consumption in my monitor which caused the issue whereas other games would only do so rarely. I'm still in disbelief that I possibly saved $230 by switching a cable, but I'm not going to hold my breath yet. Just gonna have to hope and pray this works
