Budget (including currency): 300 USD
Country: Portugal
Games, programs or workloads that it will be used for: Minecraft/Sims 4/Roblox
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Friend needs help with this budget build. He already had a Keyboard and Mouse
Cheese
https://linustechtips.com/topic/1225564-300-budget-build-help/
for 300 bucks i advise going used and get an optiplex with a 3770 and put a 1050/ti/570/580 (if it has a pcie connector).
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1225564-300-budget-build-help/#findComment-13849539
You could play minecraft with that settings on 1080p. Roblox on medium 60fps i guess? Don't know about sims 4 tho but with that spec should be running well.
https://linustechtips.com/topic/1225564-300-budget-build-help/#findComment-13851657
