recently ive been having a lot of issues playing game because it seems every time i go to click with my mouse it clicks twice. im unsure if this is a normal problem and i am unsure what to do about it.
if theres a way to fix it please let me know. RMA isnt an option either as its an older mouse.
https://linustechtips.com/topic/1225442-logitech-g502-double-click-issue/
Switch worn, just replace it.
F@H
GPD Win 2
On 7/22/2020 at 3:56 PM, DragonsRift said:
so theres no solution? i just have to spend another 60$ on another mouse?
Judging by the pictures on this aliexpress listing, looks like the switches can be disassembled, maybe cleaned or otherwise repaired. Looks like you could clean the little contacts with alcohol and cue tips or cotton swabs. With some small pliers and needles you could even try to bend the spring part ever so slightly to restore the contact force. I think this could be done without soldering. The mouse is far from being easy to open (I've done it twice). It needs to be pried pretty hard in the right spots. This video might come in handy.
you could also replace the switch.
The same switch might be used in other buttons of the mouse. You could desolder one, if it's not crucial, or double clicking wouldn't bother you. The best option would be to buy someone's g502 with a working main switch. Otherwise you gotta order it (most likely from aliexpress or similar). Then you'll most likely have to desolder the old, then resolder the new switch. Needed: soldering iron, sponge, flux, solder, wick, screwdrivers (flat and philips), old credit cards or IDs. The better option might be to use sidecutters or something and simply break off the bad switch. PCB mounted parts can be much more difficult to remove than to install. Since orders from aliexpress take a long time to ship, in the mean time you could watch some of Louis Rossmann's videos to learn the basics of soldering (sometimes he uses hot air instead of an iron, but it's the same principle). Be careful while soldering switches, especially such small ones, they can easily melt. You gotta use lots of flux and don't heat the solder contacts any longer than necessary.
fyi I repaired my middle button switch 2 times (I used to rage often). I repaired around 10 switches on my mechanical keyboard (bad batch of switches). I hate to trash electronics, especially when the faulty part is so simple and cheap.
I hope I could help
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
Usually current mice have screws under the slip pads so you need to remove them to open it and that ruins them, and unless you can source replacements the mouse will then handle like trash.
F@H
GPD Win 2
Logitech mice is known for their double click issue (I also had it in my G603) and they have this cover in their warranty, if your warranty is out, replacing the switches are your only option.
