RTX 2070 and 3900x
Nucleargamer12
Go to solution Solved by Cyracus,
They would pair very well
I was wondering if the RTX 2070 (not super) was going to pair well with the 3900x or would the bottleneck be bad. I plan on gaming both recent and older games with highest settings on.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
okay good, i heard that the 2070 would bottleneck because of how powerful the 3900x is
a bottleneck will typically be an issue the other way around where the cpu bottlenecks the gpu.
okay i thought it could go the other way around if the cpu was more than the gpu could take
