Ryzen 3700x Temps Reaching 60°-70°C While Browsing And Watching Videos
Solved by mariushm,
As long as the temperatures stay under 85 degrees, you CPU will be happy. Between 85 and around 90 degrees it will start to reduce the frequency of its cores in order to consume less power and therefore produce less heat and cool down gradually if the cooler/fan does its job. if the temperature stays high it will eventually shut down.
Your motherboard seems to adjust fan speed dynamically keeping your cpu around that temperature. It does it to keep fan speed low, making your computer less noisy.
You can go in bios and see if there's a fan curve configurator, where you can adjust the minimum and maximum fan speeds versus temperature, to have your fan spin at faster speeds even when it's cold enough.
