where do MB511 RGB case fans cables will go?
Solved by Haro,
3 minutes ago, yash5599 said:will it do any harm?
Plug it into the non argb header.
Since that header is 5v and the cable is 12v.
If the cable is a 3 pin then it's fine. If it's a 4pin unplug it.
Featured Topics
Aleph256 ·
Posted in Storage Devices0 -
15
Bonznumber1 ·
Posted in Windows0 -
aqarwaen29 ·
Posted in CPUs, Motherboards, and Memory5 -
17
10
