Hi, so I have recently bought, a Kolink Observatory case for my first ever build, but it turned out this case is too small for my CPU cooler, which is Cooler Master Masterliquid ML240L v2I think in my case its not fitting in because the RAM is to high i guess (im a newbie in PC building), because I've seen it fit in the same case for other people. My ram is Patriot Viper Steel 16 4000mhz and the motherboard is MSI MPG Z490 Gaming Plus ATX.
Im hoping some of you will know what case would be good for these parts. I was thinking about CoolerMaster TD500 Mesh, but Im not sure if it will fit in this case too. Any ideas? I would like a case with similar design, also nothing too expensive around $140. Thanks !
https://uk.pcpartpicker.com/user/Xarlaq/saved/m9WHzy
https://linustechtips.com/topic/1224264-need-help-choosing-a-case/
There's no way ram will limit your case options
That cooler should definitely fit in the case though, and around the ram. You need to take another look, read through your manuals and make sure you're installing everything correctly
Welcome to the forum!
Use PCPartPicker and select all your parts, it has a compatibly filter. So it will show all the compatible cases.
https://pcpartpicker.com/list/
The TD500 Mesh will be compatible though, and is a great airflow option, I can recommend that as a choice. Other good cases include the Corsair 275R airflow or 220T Airflow, Fractal Design Meshify C TG, and the Phanteks P400A.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
I think what he means is:  he wants to put the 240 Radiator in the top of the case and with the fans it interfers with the RAM modules. But without knowing what case he has, it's just guessing.
@Xrq when you post for help on a hardware problem, ALWAYS list ALL of your components (use a PCPartpicker list so you can easy re-use for a next post). It's makes helping much easier.
Edit: Is the CoolerMaster TD500 Mesh your actual case? I didn't get that...
8 minutes ago, ZeroStressLevel said:
The TD500 Mesh can fit a 280/360 rad on top and the front. You'll be fine with that selection BUT with that being said I would explore other options such as the P400A, P500A, Lancool 2 Mesh, NR600 and 500DX.
Ähm.. actually the TD500 explicitly says "44mm max motherboard component height"  with top  mounted radiators... the Patriot Viper Steel 16 is 44.4mm.. so he might get in trouble here.
Oh I didn't see that. Apologies and cheers for the notice.
I tried every single way, if the case was taller by like 1cm it would probably fit a the top. The only way I could fit it in at the front panel but its really too much effort for me
I will probably go with the TD500, just waiting what other people will say.
Yes thats what i meant. The case is Kolink Observatory it says in the first sentence
Here is the pcpartpicker https://uk.pcpartpicker.com/user/Xarlaq/saved/m9WHzy Ill add it in the first main post
so do you think the TD500 will be good or not?
Korben just mentioned that your ram is 0.4mm too tall for the TD500. So I'd see if the other cases I mentioned are compatible.
You could mount the radiator in the front in both cases, but I guess that wouldn't look good. So you either
- switch to a 360mm AiO (for the front)
- switch to air cooling (both cases seem very good for air cooling)
- switch the RAM with a height less than 44mm
- search for a case that fits a top 240 rad with your memory or has front that suits a 240 rad...
what about lancool II Mesh, I cant find any info about the max height for the ram
Front mounting isn't the best for an AIO. When the liquid permeates into the tubes over time and air gets introduced into the CPU PUMP block it ends up in a grinding noise which affects the lifespan and performance over time. Gamersnexus did a better explanation of why not to front mount AIO rads.
Can't (or don't want) to check it out since Lian-Li's certificate for the webpage ran out today *g*.
But according to the pictures I saw it has not much space in the top either.. .sorry.
The only case I could look up quickly that kind of fits your taste is Thermaltake View 51 TG.
It looks like you can move the top mounting for fans/radiators sidewards, away from the mainboard (please check that yourself, I just took a quick glance)
BUT: it's not meshed.. the front is glas, which I think is a bad choice for airflow.
I guess you can't change the RAM modules? (sell them and buy new ones... it may cost you some money but make your case choice much easier).
8 hours ago, Xrq said:
Ok maybe lets forget about a 'fancy' looking case, but just any good looking case, with good airflow that will be able to fit in the AIO at the top? for around $120?
What about Fractal Design Meshify C ?
The Meshify C came to my mind too, but it seems it has the same limits, as, I guess most cases have since this big RAM modules are quiet uncommon.
Sorry, but my advice still is to get rid of the RAM and get some with smaller dimensions. This way you can use your Kolink case, obvious your first choice in cases.
